Tip for Samsung F1 Spinrite 750Gb & 1Tb users installing Win7
Len
For Samsung F1 750Gb & 1Tb spinrite HDs.
If you have one of these drives you may get a disc error reported on the first reboot while installing.
There is a small bug in the firmware that prevents it from booting if you install to a formatted partition.
I found this the hardway and took 1 and a half days to track down!
The trick is to leave the partition that you intend to install to as unformatted .
Then pop the win7 disc in the drive and boot from that, choose custom install and select  the Unformatted partition, Win7 will format the partition and make it bootable at the same time  Grin
Hope someone finds this useful
Len
