Times App in ipad
tgr
Times App in ipad
have just bought an i pad they are pretty easy to use but can anyone help with the following.  I have the times newspaper app.  I have only just got it and I have read several papers and would like to delete papers i have already read but there does not seem to be a way to do this.  Deleting apps is easy just hold the app till it wobbles etc but this doesn't work with the newspapers.  Perhaps old papers are deleted once you renew your monthly subs.  Anyone got the answer thank you
Re: Times App in ipad
There are a few people complaining about this m8, there is an update which fixes this so check you have the update. If you do it should be in Times settings/clear cache.
tgr
Thank you.  I have now noticed that it appears only to keep yesterday and todays paper so prob i have the up date as i have only had it 6 days
VileReynard
Seasoned Pro
Fixes: 9
Why not look at the Guardian website on a proper Roll eyes computer?
It's free and likely to remain so.
