Thunderbirding mad!
Luzern
Seasoned Champion
Fixes: 5
Thunderbirding mad!
I'm in a fix. My side panel with my various accounts's folders has suddenly gone walkies, so I am unable to search fot  expected incoming mail. To exacerbate matters my Mozilla forum identity log on no longer works, and, attempting tor           re-register, although I answer the question, "how many letters does Mozilla have:?", the process fails.
Any ideas for my problems, please, guys?
9 REPLIES 9
Fixes: 19
Re: Thunderbirding mad!
A wild one, @Luzern  - have you inadvertently somehow 'hidden' it? Check you have something like this set in your 'View' menu: 'Classic' - with a dot, 'Folder pane' & 'Folder pane columns' with a tick - the column option is not essential if you haven't got it - just give you more options.
I would have done a screenshot, but the 'Snipping Tool' doesn't seem to play nice with non-MS applications.
Luzern
Seasoned Champion
Fixes: 5
@Gel I see another profile was created today, so all I see on opening is.
@jab1 I don't find what you suggest. Am I looking in right place?viewmenu.gif
Fixes: 19
@Luzern - No, try the 'View' menu on the left top.
Fixes: 19
Picture of what I meant:
Luzern
Seasoned Champion
Fixes: 5
@jab1 :embarrassed: Doh! Coulombs now seen, but one account still with red striped and cannot be viewed. I shall ahe to remove and re-install it.
RobPN
Aspiring Hero
Fixes: 4
@Luzern
If the menus referred to ny @jab1 are not showing, right-click on the 'Title Bar' and check 'Menu Bar'.  :wink:
If another profile is in use you may find this help article useful to start TB with your regular profile.
Luzern
Seasoned Champion
Fixes: 5
It was me, no doubt, getting nowhere. Viewing messages was hopeless, because there were red-white stripes hiding the texts. On a whim I opted to open in new window, and they were visible. Finally, in desperation, I uninstalled TB, and downloaded the program anew. It now works.
What the dickens had happened to cause my trouble, but now all is as it should be.
Thanks all.
Fixes: 19
Glad you're sorted, @Luzern  - I was just going to ask how far you'd got when then flag popped up for your reply.
