Thunderbird update
Legend
Fixes: 255
Thunderbird update
This is one for @spraxyt probably, but any contributions welcome.
I am currently using a very old (2.0.0.24) version, because to be honest, I don't like the interface of the newer versions. If I upgrade to the current stable version, will it seamlessly recreate my  current folder folders, address books &c?
I am asking this question because I am getting security warnings when opening the program (first one was this morning), and Plusnet marketing emails are totally locking up the application with a warning that a security protocol is not supported.
6 REPLIES 6
HairyMcbiker
All Star
Fixes: 21
Re: Thunderbird update
I've never had any issues updating TB, but I haven't done a major update like that.
Do an export of everything to a new folder, or just copy the mail folder, before you update.
Legend
Fixes: 255
That was one of my thoughts, HB and will be done as a back-up. Thanks
spraxyt
Resting Legend
Fixes: 75
I could only echo the comments and advice provided by @HairyMcbiker on this. However I often find having decent backups proves a good way to ensure nothing goes wrong. Funny
David
Legend
Fixes: 255
@spraxyt @HairyMcbiker
Just FYI - I installed 52.3.0 over 38.n.n without any problems on an old XP machine I still have (normally disconnected from the web, but retained as an emergency backup, and for a couple of games not compatible with X64)
However, before I do anything with it on my current machine, I am going to do a full back-up AND create a restore point - yup, maybe overkill, but I'd rather be safe than sorry.
spraxyt
Resting Legend
Fixes: 75
TBird 38 is relatively modern whereas version 2 is ancient and its software technology has changed along the way. It coped with that change at the time and I hope it still can.
Fingers crossed. Thumbs_Up
David
Legend
Fixes: 255
Glad to report that it all seems to have gone smoothly. Only things I have had to do have been to re-enter account passwords and re-jig the view, but SEEMS to be OK.
Still don't particularly like the display, but I suppose I'll get used to it.
