Thunderbird email Received Font Size
FIXED- Subscribe to RSS Feed
- Re: Thunderbird email Received Font Size
29-09-2020 11:43 AM
Some emails that I receive, have very very very small font size... how can I increase the font size ?
I know it can be done (fairly easily) for COMPOSING/sending emails...but cannot find any way of doing this for received emails.
Fixed! Go to the fix.
29-09-2020 11:49 AM
I've not tried it, @shutter , but there is a 'zoom' option in the 'view' section of the toolbar. Does that help?
29-09-2020 11:55 AM
@jab1 Yeah... that seems to work on the screen.... must try and remember that... or remember to use CTRL + + ( that is CTRL key plus + key... )
Cheers
