Thunderbird attachments:
Can't see the wood for the tree's...
When I reply to an email in Thunderbird that included an attachment, I keep on including the attachment with the reply. This didn't use to happen, I've changed something, probably accidentally, and I can't see what I've done!! nothing in options/attachments seems to help...
