Thunderbird address book
FIXED- Subscribe to RSS Feed
- Re: Thunderbird address book
08-07-2016 9:40 AM
Curiously, in "Write" (a new email) my Thunderbird the address book listings have of their own volition turned themselves upside down with the A's at the bottom and the X,Y,Z's at the top.
If I press the the "Address Books" button the listings in there are correct order (A's at the top) so this anomaly only affects the "Write" option.
However: a) I don't know how this happened, and b) I can't see any way to change it back. There being no simple option to view ascending or descending. Its annoying more than anything else, all of my group lists that are usually at the top and have now to be scrolled to the bottom to find them.
Any one any ideas how to reset the listings?
Fixed! Go to the fix.
08-07-2016 10:01 AM
in the header, where it says "Name" you will see a small triangle pointing upwards or down wards... just click inside the header and it will change the a-z or z-a format
Simples ! !
08-07-2016 1:38 PM
Ah!! thank you
