Thumbnail cache in Windows 7
nozzer
Anyone know how to disable it to avoid creating thousands of thumbnail files?
3 REPLIES 3
Mav
Fixes: 515
Re: Thumbnail cache in Windows 7
Tools > Folder Options... > View tab > Always show icons, never thumbnails.
Forum Moderator and Customer
Oldjim
Resting Legend
Fixes: 63
If you change the folder default view to details or list I believe that does it.
You can do it on a per folder basis but then you would need to delete the thumb.db file afterwards as I believe the Windows default is to use thumbnails whenever the folder contains pictures
nozzer
Thanks folks!  Smiley
