Thumbnail cache in Windows 7
- Thumbnail cache in Windows 7
10-06-2011 1:52 PM
Anyone know how to disable it to avoid creating thousands of thumbnail files?
3 REPLIES 3
Re: Thumbnail cache in Windows 7
10-06-2011 2:13 PM
Tools > Folder Options... > View tab > Always show icons, never thumbnails.
Forum Moderator and Customer
10-06-2011 2:15 PM
If you change the folder default view to details or list I believe that does it.
You can do it on a per folder basis but then you would need to delete the thumb.db file afterwards as I believe the Windows default is to use thumbnails whenever the folder contains pictures
10-06-2011 2:18 PM
Thanks folks!
