Thomson gateway router
beanie2blue
I have a Thomson Gateway Wireless Router which works great as long as the phone dosent ring!!
when the phone rings i often lose complete connection but it resumes after 30 seconds or so after i hang up the phone although sometimes i can still use insant messaging.
any ideas what could be causing this ? the router is only a few weeks old.
many thianks
Denzil
Re: Thomson gateway router
The first thing to check is the microfilter - I assume you have one fitted? The filter should plug into the phone socket, then the router cable and the phone plug into the filter. Filters can fail, so try a new one, or try one of <a href="http://www.adslnation.com/products/xte2005.php">these</a>, which are generally highly rated.
beanie2blue
Thanks Denzil i will check the one i have fitted and post back .
beanie2blue
Thanks Denzil for your help i think that is what the problem was, the filter must have been faulty.
Thanks again Grin
Denzil
Glad it is sorted.
