Thomson/ Technicolor aficionado please- port closing help
- Thomson/ Technicolor aficionado please- port closi...
31-12-2014 1:51 PM
Prior to PN, I was using Sky with their router. I noticed no entries in the router log trying a brute force attack, neither did I know about Shields Up for testing either. Upon moving to PN, I used the 582n which is set up basically by PN with their firmware. I never saw any intrusions into the logs on that device. As soon as I used the new Tg589v3, I am inundated with attacks from various Asian ip addresses.
You can see from the previous post some of the solutions proffered me, but none appear to work and I don't really want upnp off unless I really have to. I am hoping there is some Technicolor bod out there that will be able to explain to me in "Noddy" terms what I need to do to stealth port 22 please. This port is open by default out of the box as I have reset the router with nothing attached to it and Shields Up still finds it.
Thank you in advance anyone taking the time to read this.
Mark
Re: Thomson/ Technicolor aficionado please- port closing help
31-12-2014 2:53 PM
Quote from: Marksfish I downloaded putty and got access to 22, but don't know the password as I haven't set one up, so not sure where to go from there.
I think it will be the same username and password hat you use to access the router's setup webpages. I didn't think it is possible not to have one, either there's the default username and password, or it prompts you to set one when you first enter the details it needs to connect to Plusnet.
31-12-2014 3:11 PM
So being able to access it, means it needs to be shut somehow.
Mark
31-12-2014 3:23 PM
Quote from: Marksfish So being able to access it, means it needs to be shut somehow.
Well yes and no !
It is one thing for you to be able to access the router using SSH from your LAN, and that is normal.
The problem you have is that somehow your router is allowing SSH to be accessed from the WAN (internet) port !,
and it is this external access that you need to prevent.
That is why I suggested setting up a port forward to a non-existent LAN IP address, as that should redirect the router's external SSH port to somewhere other than the router's WAN interface.
31-12-2014 3:31 PM
Mark
31-12-2014 3:38 PM
After connecting to the router using SSH, please enter the following command and post the output.
:service system list
31-12-2014 3:44 PM
| | o |
MediaAccess TG589vn v3
10.5.2.F.BN
Copyright (c) 1999-2013, Technicolor
{Administrator}=>:service system list
Idx Name Protocol SrcPort DstPort Group State
1 CWMP-C tcp over ipv4 enabled
2 CWMP-S tcp over ipv4 51005 enabled
3 DHCP-S udp over ipv4 676 enabled
4 DHCPv6-C udp over ipv6 547 546 disable d
5 DHCPv6-R udp over ipv6 547 enabled
6 DHCPv6-S udp over ipv6 547 enabled
7 DNS-C udp over ipv4 53 enabled
8 DNS-S ip 53 enabled
9 DYNAMIC_DNS enabled
10 FTP tcp 21 enabled
11 GRE gre over ipv4 disable d
12 GWRD tcp over ipv4 disable d
13 HTTP tcp 80 enabled
14 HTTPI tcp over ipv4 8080 disable d
15 HTTPs tcp 443 enabled
16 IGMP-Proxy igmp enabled
17 IP6TO4 ipv6 over ipv4 disable d
18 IP_COMMANDS enabled
19 IP_REDIR icmp 5 disable d
20 IPIP ipencap disable d
21 IPv6_MANAGEMENT ipv6-icmp enabled
22 L2TP udp over ipv4 1701 1701 disable d
23 MDAP udp over ipv4 3235 enabled
24 MLD-Proxy ipv6-icmp 143 disable d
25 PING_RESPONDER icmp 8 enabled
26 PINGv6_RESP ipv6-icmp 128 enabled
27 PPTP enabled
28 Remote-MBus tcp over ipv4 2006 disable d
29 RIP udp over ipv4 520 520 disable d
30 SLA_ICMP_PING icmp 8 enabled
31 SLA_ICMPv6_PING ipv6-icmp 128 enabled
32 SLA_UDP_PING udp 7 disable d
33 SNTP udp 123 123 enabled
34 SSDP udp over ipv4 1900 enabled
35 SSH tcp 22 enabled
36 SYSLOG udp over ipv4 514 disable d
37 TELNET tcp 23 enabled
38 TFTP-C udp over ipv4 69 disable d
39 UPGD-C ip over ipv4 enabled
40 WEBF tcp over ipv4 80 disable d
41 webservice tcp 9000 disable d
31-12-2014 3:45 PM
Mark
31-12-2014 3:58 PM
Quote from: Marksfish Sorry, not sure how to format the output:
The simplest method of formatting that sort of text is to use the '#' (Insert Code) button above the forum text entry box.
When you copy and paste the text, immediately before you paste, press the '#' (Insert Code) button, and then paste the text.
It will then come out like this -
| | o |
10.5.2.F.BN
27 PPTP enabled
31-12-2014 3:59 PM
31-12-2014 4:11 PM
:service system list name=SSH expand=enabled
31-12-2014 4:24 PM
31-12-2014 4:27 PM
Quote from: ejs I was hoping for a little more information in the output.
Does this help?
# 1 SSH tcp 22
Description................ SSH server
Properties................. server
Attributes................. state port aclip aclif aclifgroup map log qoslabel routelabel natpmweight
User Managed Attributes.... state aclip aclif aclifgroup map log qoslabel routelabel natpmweight
Attribute Values :
State...................... enabled
Port....................... 22
QOS Label.................. None
Route Label................ None
NAT Portmap Weight ........ 10
Ip Access List............. any
Interface Access List...... any
Interface Group Access List any
Map List................... 22
Logging.................... disabled
31-12-2014 4:34 PM
:service system ifadd name=SSH group=lan
Followed by
:saveall
to save the configuration.
Then re-check if port 22 is open at http://canyouseeme.org/ or the GRC Shields Up website.
31-12-2014 4:50 PM
Quote Your system has achieved a perfect "TruStealth" rating. Not a single packet — solicited or otherwise — was received from your system as a result of our security probing tests. Your system ignored and refused to reply to repeated Pings (ICMP Echo Requests). From the standpoint of the passing probes of any hacker, this machine does not exist on the Internet. Some questionable personal security systems expose their users by attempting to "counter-probe the prober", thus revealing themselves. But your system wisely remained silent in every way. Very nice.
Thank you to everyone that took the time to try and help me with this issue, on this thread and the other. Just the webcam port open now, i'm happy with that.
Mark
