Thomson TG585v7 crashes (web interface & wireless)
- Re: Thomson TG585v7 crashes (web interface & wirel...
31-12-2009 5:44 PM
I am using the TG585v7 merely as a 4 port switch & as a wireless access point. My internet connection is through a SOLWISE SAR-110.
i have recently discovered that the router will fail to allow new connections to the wireless & at the same time, the internal web interface /server also crashes.
The solution is to restart the device, but when this happens every day it is getting rather irritating.
Interestingly, the ethernet switch side isn't affected when the rest of the router crashes.
If anyone could shed some light on this problem, it would be much appreciated.
Many Thanks
Mark
Re: Thomson TG585v7 crashes (web interface & wireless)
01-01-2010 1:09 AM
PN are aware (as are thompson) but no new firmware version has been released to fix it yet (and I'm not sure if there will be as it's been known for a long time and the product has been replaced with 585v8 model).
01-01-2010 11:26 PM
02-01-2010 2:39 AM
02-01-2010 12:55 PM
Or have they not fixed the problem in the 585v8 release?
Cheers
Mark Wrightson
06-01-2010 7:41 AM
16-01-2010 12:14 PM
22-03-2010 3:37 PM
31-03-2010 9:21 PM
31-03-2010 10:35 PM
01-04-2010 9:34 AM
01-04-2010 1:15 PM
FWIW, there's a new version of the Thomson firmware available that I uploaded here yesterday.
01-04-2010 4:18 PM
03-04-2010 11:09 AM
03-04-2010 12:52 PM
