Thomson TG585 v7
stuples
Thomson TG585 v7
Hi
I'm trying to get VPN working and I'm struggling.
I'm using the Thomson TG585v7 router.
I've got port 1723 (PPTP) forwarding to the only computer connected. This has been verified via some online port scanner. I've also turned off the firewall on the router.
The problem lies in the fact that I still cant get connected.
I've had this working before in my old house with a different ISP and a different router so I know the VPN settings on my computer work. I've checked them to make sure that they haven't changed.
Is forwarding that port the only thing I need to get the router to do? Is there some way I can check that protocol 47 is also being correctly forwarded?
Stu
Fixes: 35
Re: Thomson TG585 v7
Are you just trying to use a VPN client to connect to a remote VPN server ? If so then you shouldn't need any port forwarding, thats only needed if you are trying to run a VPN server locally.
One possible difference from your old configuration my be the subnet of the TG585 router. I think the 585 uses 192.168.1.x , is your remote site behind a NAT router with the same 192.168.1.x subnet by any chance ? If so you need to change the subnet of the 585.
stuples
Yea, I didnt think I needed port forwarding but I couldnt think of anything else to do :p I'll turn them off.
Here are the details (copy and pasted):
Protocol: PPTP (ports 1723 and protocol 47)
Authentication protocol: MSCHAPv2
Data Encryption: 128bit
Maximum throughput: 1Gb
IP addresses range: 10.56.X.X
DNS range: x.vpn.local
Does that help?
Fixes: 35
I'm not sure I understand those settings , what's the VPN client ?
I'm guessing that this is the remote IP range , if so it shouldnt be a problem.
Aha!! What's the setting on your PlusNet firewall ? https://portal.plus.net/my.html?action=firewall
Needs to be LOW or OFF
stuples
Quote from: MisterW
It's off.
I've been trying to connect through Ubuntu and I've just remember that VPN is a bit of a pain in the ass. So I rebooted into Windows and tried out my VPN connection there and it worked fine. Sigh, so it's something in Ubuntu that's the problem.
Thanks for your help.
Fixes: 35
I think I lost my brain back there for a while. Anyway glad you got it working , with Windows at least.
Funnily enough I use Ubuntu and don't have a problem with VPN to my office with either that or Windows.
However I dont use the default configuration for routing ( see attached screen dump ). Rather than route all traffic through the VPN tunnel
I set it to ONLY route traffic for the remote private subnet.
