Thomson Gateway & VPN
- Thomson Gateway & VPN
27-03-2010 2:13 PM
I have a Thomson Gateway TG585 v7, for my sins it seems.
Trying to connect to my VPN but can't, I could previously connect to it fine using a different ISP and router.
When I enter the username/password for the VPN it doesn't connect, although there is nothing wrong with the connect.
My ISP firewall is set at low, I can't change the settings for the router.
Help???!!
Much appreciated.
Help???!!
Much appreciated.
1 REPLY 1
Re: Thomson Gateway & VPN
27-03-2010 8:11 PM
welcome to the Forums.
The person you want is Bob Pullen, Plus Net Staff, he doesnt work week end, but soemtimes pops up, their is a work round, but I dont know it
