Thompson TG585 v7 Query SOLVED
Steve
Seasoned Pro
Hi since ive installed windows 7 on my new pc i have noticed that the router is addportmapping to my pc ip address,i have upnp enabled and i have that for my xbox 360,i have no service assigned with my pc as i never had to do that before.
But now every minute when i look into my event log add portmapping is succesfully enabled for my pc ip?this is not correct,am i missing something?
Ive reset the router to the factory settings but this is still happening?
If life gives you lemons, make lemonade.
Steve
Seasoned Pro
Re: Thompson TG585 v7 Query
Problem solved thanks for the help!!
chrisjbzero
Re: Thompson TG585 v7 Query SOLVED
Steve, I have a similar problem.  I wonder how you solved it?
Steve
Seasoned Pro
Hiya it actually solved itself,after a while it deletes the portmapping,now using a netgear wireless n with no problems.
