Thompson TG 585v7 Router question
elf
Hi to the Plusnet community for the first time.  Smiley
Could anyone please tell me what the button; with the wireless symbol on, is for on my router?
I was hoping it was to turn the wireless facility on and off.
The explanation on the technicolor website is:
"......and a physical user registration button, which allow users to communicate and access data with efficient link quality and the highest level of network security. "
Much appreciated.
pierre_pierre
Re: Thompson TG 585v7 Router question
Welcome to the Forums Mr Meerkat
Sorry my Thompson router is an older one where that button didnt work
W1ngD1ngs
The manual which can be downloaded from:  http://office.manualsonli...on_multimedia/585_v7.html
Apparently it claims in the manual:
"Registering Clients via the Association Button
Proceed as follows to register new wireless network clients via the association button:
1 Push the Registration button on the Thomson Gateway front panel and hold it for at least two seconds.
2 The WLAN LED toggles between green and red.
3 The Thomson Gateway unlocks the Access Control List for one minute. Wireless clients configured with
the correct wireless settings that try to connect to the Thomson Gateway will be added to the list of
allowed devices.
4 Depending on your wireless client adapter, a wireless icon may become green or a message similar to
the following may appear: “Successfully joined Wireless network Thomson123456”.
5 After one minute, the Thomson Gateway locks the Access Control List again.
Some wireless clients do not automatically join a wireless network. If that is the case, follow
the instructions for the wireless client software to initiate the association.
The registration procedure can be repeated as often as needed.
Cool
W1ngD1ngs
Whoops! Bad link.  This is better http://office.manualsonli...on_multimedia/585_v7.html  Crazy
W1ngD1ngs
