Thompson Router
Cormorin
Thompson Router
I have a Apple TV and keep needing to restart my router to connect with AirPlay.
Are there aNy fixes
Fixes: 113
Re: Thompson Router
might be worth checking you're not affected by this http://9to5mac.com/2013/04/15/apple-says-small-number-of-apple-tvs-have-wifi-issues-opens-replacemen...
Will Moderate For Thanks
Fixes: 19
Re: Thompson Router
Any particular Thompson router?  It might be worth checking that the router firmware is up to date.
