Thompson Gateway Router Tg585 V7
- Thompson Gateway Router Tg585 V7
- « Previous
- 1
- 2
- Next »
Re: Thompson Gateway Router Tg585 V7
29-01-2010 10:43 AM
29-01-2010 12:00 PM
29-01-2010 12:29 PM
if you follow this it tells you how to make the IP address fixed so it doesn't need the router to assign it
I think the correct format for the 585v7 is 192.168.1.* where * can be any number between 1 and 253 - try using 1
You can check the current setting by opening a DOS prompt and typing "ipconfig /all" without the quotation marks and noting the gap between ipconfig and / this will show something like this and the bits you want is the IP address and subnet mask
29-01-2010 4:32 PM
connection :Lan
description : NVIDIA nForce Networking Controller
physical address :00-13-8F-D9-B1-02
dhcp enabled :Yes
autoconf enabled :Yes
ip address :192.168.1.64
subnet mask :255.255.255.0
default gateway :192.168.1.254
DHCP server :192.168.1.254
dns server :192.168.1.254
lease obtained 29 January 2010 15.59.42
lease expires 30 January 2010 15.59.42
how do you send an image to the forum?
must go and do the weekly shop with the wife
29-01-2010 4:47 PM
If you go into the router and click on Home Network and then on Devices it might show all the connected devices with their IP Addresses
29-01-2010 7:06 PM
thanks for your help, but I am a little bit lost, how do I go into the router?
29-01-2010 7:45 PM
Detected Device(s)
The table below contains the list of devices the Thomson Gateway detected on your local network. Click on a device name to get more information on a device.
Name IP Address Interface
Thomson Gateway dsldevice 192.168.1.254
asus-1462820603 192.168.1.68 WLAN Interface WLAN
owner-33d4a474f 192.168.1.64 WLAN Interface WLAN
computername 192.168.1.66 Ethernet Interface unknown
your-dde8876fe8 192.168.1.65 Ethernet Interface ethport1
acer-4d025c48b8 192.168.1.66 Ethernet Interface unknown
peter-PC 192.168.1.66 WLAN Interface WLAN
computername 192.168.1.67 WLAN Interface WLAN
29-01-2010 7:47 PM
Just read this thread and im aware computeryydidgeryydooing is not your strong point,try clicking this link and enter username and password....http://192.168.1.254/
29-01-2010 8:10 PM
29-01-2010 8:31 PM
1. the security codes
2. the username and password to get into the router and
3. your username and password with Plusnet to access the internet.
The one that steve is talking about is to get you into the router's interface.
As steve says, type 192.168.1.254 in the address bar then the username is Administrator and the password is what you put in when you set it up.
Now, if you didn't put a password in and are using the default one, here is the info from the PN site:
Quote Next choose a Username and Password, this is to secure your Thomson Gateway.
You should choose something that's easy to remember as you'll need these details to check or change your router settings in the future. If you don't make any changes then the Username will be Administrator and the Password will be the Serial Number on the bottom of your Thomson Gateway (See What are the router username & password? for more on this).
However, do not be concerned if you can't get into the interface of the router as it is quite easy to reset it. Someone will talk you through that if needs be.
It's a strange problem and would like to know if it can be sorted and what is wrong.
http://www.plus.net/support/broadband/hardware/t585v7.shtml#routerDetails
07-02-2010 10:44 AM
07-02-2010 1:25 PM
- « Previous
- 1
- 2
- Next »
