This weird trick can win you Gigabytes of extra hard disk space
ReedRichards
Seasoned Pro
Fixes: 25
Disk Cleanup on Windows 8 and latterly on Windows 7 provides a new option to remove the files left behind by Windows Updates that have been superseded by other updates.  I tried it on two machines that have long-established copies of Windows 7 and in both cases it won me over 6GB of extra hard disk space.
The procedure is described here http://www.techrepublic.com/blog/windows-and-office/regain-hard-disk-space-by-using-windows-update-c...
However there is a slight sting in the tail.  You may think you have done the clean-up but it completes when you next restart Windows and that may take quite some time.  You'll see a screen saying Windows is Configuring Updates 100% complete for some minutes then a clean-up screen which also runs for a good while, about 20 minutes total start-up time my the worst case.
32 REPLIES 32
twocvbloke
Re: This weird trick can win you Gigabytes of extra hard disk space
Disk cleanup's been a thing since about Windows95 (probably earlier too, been a while since I looked at 3.1), never really works cos as soon as it's done, windows refills the freed-up space with more of it's rubbish...
HPsauce
Indeed, it is very useful.
Just the other day I was given a small HP notepad to sort out with major W8.1 performance issues; it had run out of space on its relatively small (64GB?) SSD disk and "lost" the swap file too.
The first thing disk cleanup found was an awful lot of temp files, but after that I did the cleanup of system files, updates and restore points.
When I finished it was less than 50% full even after I had allocated a suitable swap file.  Cool
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: twocvbloke
Disk cleanup's been a thing since about Windows95 ...
But this is a new type of clean-up that cleans areas other clean-ups cannot reach!  Really.
Specifically it was not originally in Windows 7 but arrived via an update in 2013 so you could easily have missed finding it.
Kremmen
Fixes: 5
I know Disk Cleanup is the only safe way to remove the Windows.old file after an upgrade.
Must go and have a look at this latest version. I've only got about 1.5Tb free  Smiley
Let's be careful out there !
Mav
Fixes: 515
Just had a look into this as I have over 15GB in winsxs.
Since installing the OS on an SSD Disk Cleanup for that drive has never appeared when right-clicking and selecting Properties yet it appears for the SSD that doesn't hold the OS and for all other internal and external drives.
I ran Disk Cleanup from the Start Menu > Run but all it found was a tad under 1 GB of files to delete with no Windows Update Cleanup option showing. There is a Service Pack Backup Files but that was zero.
I wondered whether the update had been installed so went to MS Download Centre (KB2852386). On running it I am told this update has already been installed.
So I am still stuck with >15GB of files in winsxs Sad
Forum Moderator and Customer
Kremmen
Fixes: 5
Found it and ran it.
The updates cleaner removed 600Mb.
Good spot
Strat
Fixes: 565
2.4GB removed in my case Smiley
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: Mav
Did you scroll down the list to see all options?  I think it was towards the bottom and not visible until you scroll
Quote from: Kremmen
Quote from: Strat
2.4GB removed
The longer you have been running your copy of Windows, the more superseded updates there will be to remove and the more you will benefit.
Mav
Fixes: 515
Quote from: ReedRichards
Quote from: Mav
Yep
shutter
Fixes: 65
Helene Fischer seems a bit worried about me deleting 3.58 GB of files....
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: Mav
Yep
When I ran the Cleanup again it said it was checking Windows Updates but then the option to delete them did not appear in the check list.  Presumably it's only there as an option if there is something to be removed.
Mav
Fixes: 515
I wondered that but there were other options with zero bytes so I was kind of expecting something to be displayed.
ejs
Aspiring Hero
Fixes: 25
I have seen Windows Update want to re-install a small number of already installed updates after completing the Windows Update cleanup. Not a big problem, it just ends up installing a couple of updates again (or possibly just attempting to install them then realising they're already installed).
Mav
Fixes: 515
I have just performed the same operation on my laptop which found over 4GB of files under Windows Update Cleanup.
I'm wondering whether it is different with SSDs Undecided
Further research and I came across the DISM command (DISM /online /Cleanup-Image /SpSuperseded). Having read several articles I tried that with the following result:
Service Pack Cleanup can't proceed: An operation is pending on this computer. Restart your computer, and then run Service Pack Cleanup.
The operation completed successfully.
I haven't rebooted after running Disk Cleanup as I wasn't prompted to do so. Maybe will boot a little later and try again.
