This is a test (with a great big image in it)
VileReynard
Fixes: 20
 Note:- Plusnet appear to reduce images to max of 600 x 600px - that's great on a 1080 x 1920px screen.
5 REPLIES 5
Legend
Fixes: 255
Re: This is a test (with a great big image in it)
Well.............................it works.Smiley
Oldjim
Resting Legend
Fixes: 63
If you look at the html code for your post you will see they don't but the maximum width in the post window is 600px
VileReynard
Fixes: 20
Should I have to mend Plusnet's buggy HTML code?
Oldjim
Resting Legend
Fixes: 63
Why should you need to - it works as it should in terms of what people see
The fact that the base image as stored in your library is larger is of no relevance
VileReynard
Fixes: 20
I always look at images through the vertical equivalent of a letter box.
In fact, I keep my TV in a shoebox - I can't cope with this new-fangled wide screen idea.
So I'm grateful to Plusnet for messing up any images I send. Crazy2Crazy2Crazy2
