This is a test (with a great big image in it)
FIXED- Subscribe to RSS Feed
- This is a test (with a great big image in it)
19-08-2016 7:33 PM - edited 19-08-2016 7:41 PM
Note:- Plusnet appear to reduce images to max of 600 x 600px - that's great on a 1080 x 1920px screen.
Fixed! Go to the fix.
19-08-2016 7:42 PM
Well.............................it works.
Re: This is a test (with a great big image in it)
19-08-2016 7:48 PM
If you look at the html code for your post you will see they don't but the maximum width in the post window is 600px
19-08-2016 7:51 PM
Should I have to mend Plusnet's buggy HTML code?
19-08-2016 8:06 PM
Why should you need to - it works as it should in terms of what people see
The fact that the base image as stored in your library is larger is of no relevance
19-08-2016 8:23 PM
I always look at images through the vertical equivalent of a letter box.
In fact, I keep my TV in a shoebox - I can't cope with this new-fangled wide screen idea.
So I'm grateful to Plusnet for messing up any images I send.
