Thinking of a laptop
jelv
Fixes: 10
I'm looking at this one: http://direct.tesco.com/q/R.210-8264.aspx
Tesco have the voucher exchange scheme running at the moment I have enough Tesco vouchers to use which effectively means I would get it for £200.
Any comments or alternative suggestions (from http://direct.tesco.com/q/N.1999033/Nr.99.aspx obviously!).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
23 REPLIES 23
shutter
Fixes: 65
Re: Thinking of a laptop
I have one of these.... but more basic spec....  only problem I have found with it, is the " earphones and mic socket is in the middle front between your hands when typing..... tends to get in the way... esp if the lead is dangling down and you want to get up for coffee, ....... have often got my feet caught up in it.... ( thinks... I could put the lead around the back so it is tucked up out of the way ! ! ! )... would have been better on the side...
I have it switched on and in use pretty much from 8 am to 10 pm daily.... so gets some use....
ReedRichards
Seasoned Pro
Fixes: 25
Pentium is at the lower end of Intel's current range of processors, though it is dual-core.
Doesn't have unreliable Nvidia graphics, that's a plus.
Only wireless g, not wireless n.
HDMI output is good, do they still have a VGA output though?
It's not bad value for money at £400 so a bargain at £200.
barky
hmmm ... I'd sooner go for this one http://direct.tesco.com/q/R.209-9076.aspx
toshiba's seem to be a bit better than dell's these days -- according to many reviews
it's got b,g,n wifi & what appears to be a decent software bundle for same price
ReedRichards
Seasoned Pro
Fixes: 25
Yes, Barky makes a good point.  The Toshiba has the same processor as the Dell, wireless n instead of g but VGA instead of HDMI output.  Toshiba do make some good inexpensive laptops.
KenA
My daughter has the Dell one, and I would agree with Shutter's comments.
Also the screen is very glossy and reflects everything, difficult to focus on for long periods - though most home laptops have glossy screens now, only the more expensive business range have the matte screen, though I believe you can get anti-glare films.
Otherwise, it's a great laptop for the price.
VileReynard
Fixes: 20
Nothing wrong with a bit of sand-paper. Roll_eyes
shutter
Fixes: 65
@ A Fox is Evil....... Especially if it has "Linux" printed all over the back , and is of the coarsest grade possible. Roll_eyes
7up
Fixes: 17
Quote from: shutter
Oh you just had to say it didn't you  Grin
matt_2k34
Toshibas quality is somewhat questionable of their cheaper laptops.
Dell i find hideous.
id pick the Tosh over the Dell anyday.
Samsung is my choice - however tesco dont have any 'good' samsung branded laptops.
Depends what you want it for Jelv ?
jelv
Fixes: 10
General use, bit of office, email, general browsing, probably watching programs on iPlayer and VPN/remote desktop in to the office.
Edit: the one thing I can absolutely rule out is gaming!
Santiago
I have had several Dell Latitude laptops for work, which are excellent. Good prices from Dell Outlet.
At home we have a couple of mid range Acer laptops, both over 3 years old and, except for a replacement battery from ebay, both trouble free.
From my experience, I would recommend both brands.
I have learnt that it is not wise to buy expensive laptops because you never get value for money. Mid range is the way to go.
jelv
Fixes: 10
Quote from: Oddball
If you read above I'm looking to get one half price from Tescos!
matt_2k34
For half price jelv, i wouldnt complain because you wont be stressing it.
For updating drivers, or reformatting, theyre abit of a pain.
Your quite knowledgable - you should be fine with it though im sure Wink
for 200 notes, its not a bad deal Smiley (but id go for the tosh out of the two!)
Santiago
Quote from: jelv
Quote from: Oddball
Yes I did read above. You asked for comments or alternatives. I wish I hadn't bothered
