The clocks going back an hour question
Infinity
Seasoned Pro
With the clocks going back an hour Sunday morning (Fall Back), is the extra hour immediately in effect at 2am, ie can we surf unlimited for the extra hour till the new 8am on Sunday ?
pierre_pierre
Re: The clocks going back an hour question
I wouldnt trust the PN clock, they got it correct this spring, but they have has a bad record in previous years
Infinity
Seasoned Pro
Pierre has the solution, see next two posts #3, #4, , thanks.
pierre_pierre
just look at your forum entry, that has the time on it
Infinity
Seasoned Pro
That's a good idea.
« Last Edit: Today at 08:19 by PlusComUK »[color=blue][/color]
Post edit time is also there, no need to post a new post.
http://www.mybroadbandspeed.co.uk/
PN Speedtest also gives a time, not sure if it's linked to PN time.
Looks like the government is having another look at permanently changing to BST. Amendments are to be made to the Bill before Parliament at present.
Time Changes
Fixes: 62
And the Scots Nats say they are going to block it - I think we should ignore them and make the change for England and Wales (assuming the Welsh Parliament agrees)
I have to agree with you Jim.  The Scots have always opposed this change and we should ignore them.
Fixes: 62
As a more general point - from previous experience - forum time is totally unrelated to Plusnet monitoring times.
It rather depends on how and when the various time servers change as I don't think they are linked
Quote from: artmo
At your peril  Grin
I remember the last time they experimented with this nonsense, around 1968-1971, and it was still dark at 10am up here.
Fixes: 4
As they say in Scotland -
Ye can try an' tak' awa' uir daylecht, but ye willnae tak' awa' uir freedom !
(using the whoohoo.co.uk Scottie Translator!)
Wink
Infinity
Seasoned Pro
I'm going to edit this post before I posted it !
Edited at 01:04
PN Clock HAS updated
Fixes: 10
The service status RSS feed has gone screwy again!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Infinity
Seasoned Pro
Just received this email, at the correct time after clock reset back one hour
