The Parameter is incorrect
Fixes: 9
I have been trying to update my Garmin sat Nav but am getting stuck with a message that ......The parameter is incorrect.
There is a download program which installs ok and shows that an update has been found when I run this along with version number etc but when I try to download this I just get the parameter is incorrect.
Anyone got any ideas about this please ?
Using windows 7  32 bit.
pierre_pierre
Re: The Parameter is incorrect
not sure if this will help, the Garmin have an old and newer model download procedure, and that is different to most other makes
http://www.pocketgpsworld.com/uksafetycameras-garmin.php
you might have to be signed in to get the video
http://www.pocketgpsworld.com/showmedia.php?src=Installing-Garmin-Speed-Cameras.swf&h=400&w=640&type...
Fixes: 9
Thanks for that link, tried it but am now getting an unspecified error.
What I am trying to do is get rid of the annoying bleeps that occur once you get near a speed camera other than turning the sound off.
Have been in touch with Garmin who confirm I am using the correct software download but offer no ideas on the incorrect parameter message.
Guess I may have to give it up as a bad job !
