That "B" key again ! FIXED !!! YEE HAGH!!
shutter
Fixes: 65
Dell Inspiron 1545 laptop, ....
every time I type a word with the letter b in it, e.g. better, because, brick, the cursor moves to wherever it feels like, usually into the middle of another word in some previously typed text. and typing continues from that point....
As I use "correct keyboard touch typing" with all fingers and one thumb, it is sometimes not easy to spot where the cursor has jumped to ! until I am well into the sentence,
I have tried to "brush" out any bits of food,  with a nice little keyboard brush, but nothing appears, and also I am not going to try to lift off the key top !... they are very difficult to get back on again.
anyone any ideas..... (except perseverance !) Cheesy Grin Grin
12 REPLIES 12
Fixes: 1,483
Re: That "B" key again !
You're not brushing the trackpad with your thumb or palm are you?
Strat
Fixes: 565
I once had that problem with a Laptop with a particularly sensitive pad.
Solution was to temporarily turn off the pad with the nearby switch.
shutter
Fixes: 65
I did think of that, as the "space" thumb is always "hovering" .... not sure about switching off the pad, would be good if I could, cos I use a mouse anyway... so... just to make sure... how do I switch off the pad?
cheers for the suggestion Smiley
pierre_pierre
Try Control Panel, Mouse, disable the pad, do that in reverse to start it
shutter
Fixes: 65
Tried to disable the HID  (human interface device) but that disabled the mouse, and the pad was still working......
also have a PS/2 usb connected device (mouse) but didn`t bother with that as it has to be another name for the same mouse ! ...#
no mention of disabling the touchpad...  Undecided
pierre_pierre
not on vista, just the old XP, but I have a touchpad icon on my task bar and that has a radio button with the pad and a plain mouse as options, as did the control panel
shutter
Fixes: 65
Despite the "off the cuff" topics supplied by Pierre, I still don`t know how to disable the touch pad...... I have checked in the Control Panel, but it only mentions the mouse....
as far as I can recall the software "driver" is by synaptic.... but that doesn`t mean much to me. !  Undecided
any "really useful" comments to try will be gratefully received....  Wink
thanks
HPsauce
This sounds like a touchpad driver problem - i.e. the wrong/inadequate one is installed.
I'd go to the Dell web site and look for touchpad drivers for your model by entering the Service Tag.
I do recall a while back turning off some touchpad features on a Dell laptop for an elderly lady as it was confusing her. It was pretty simple and obvious but I just don't recall how exactly.
Edit: Just checked my old Acer laptop - Fn-F7 turns the touchpad on and off on that, maybe something similar on the Dell?
I hate touchpads so nearly always plug a mouse in which often also disables the touchpad.
shutter
Fixes: 65
HP Sauce, thanks for the response.... this problem has only happened since the "re-install" , so may well be a driver problem.... but I did use the driver disc supplied with the laptop, so would not have thought there would be a problem with them....
All the Fn buttons have a little icon on them on this Dell, Fn7 is mute the speakers/sound  Fn6 does not have any icon, but doesn`t turn off the pad either  Cheesy
Will check out the service tag, and download the driver, to see if it is that,  Plugging in the mouse does not disable the touchpad... !  Undecided unfortunately !
laura
have you looked in BIOS to see if there is a way to disable the touchpad?
shutter
Fixes: 65
Ooooh !... no!.. hadn`t thought of that either !... if the download doesn`t fix it, will go and get my torch out, and see what is lurking down there !... thanks  Wink
shutter
Fixes: 65
HP Sauce..... you get the prize !... have downloaded the requisite driver, installed it, and re-booted the laptop, and it seems to be working properly now..... thanks very much. Wink
Won`t need to get the torch out now !  Cheesy
