Text to columns. arrgh!
- Re: Text to columns. arrgh!
17-05-2008 1:25 PM
I am using Excel to analyse my BT bill. In it is a column for duration of call in format hh:mm:SS
I want to separate the elements in to separate columns so I may recalculate the minutes in decimal. However when I try, all I get in each column are 0s, so that 1:25:23 becomes
00:00:00
What may I be doing wrong, and secondly how should I go about my task, or is there a better way to recalculate the BT data as minutes and parts of minutes in decimal form?
00:00:00
4 REPLIES 4
17-05-2008 1:53 PM
The way I would do it is just do a text to columns on the duration column. Do it as fixed width and separate at each colon. On the next screen you can choose to not import the colon columns then you should have each number in a separate field.
EG
00:05:37 becomes: 0 5 37
Jeff
EG
Jeff
17-05-2008 1:59 PM
Another way is to use the functions HOUR() MINUTE() and SECOND() functions on the time cell.
Jeff
Jeff
17-05-2008 7:44 PM
17-05-2008 11:59 PM
The column needs selecting and the format setting for time as well
