Text size
Luzern
Champion
Fixes: 5
Text size
I use Mozilla. As a septuagenarian my eyes are not the best. Is there any way to set the default print size larger than what now is on screen.
7 REPLIES 7
Re: Text size
View -> text size and select what you want to do.
Fixes: 62
Re: Text size
As a quick work around - assuming it works like Firefox - press Ctrl and + which increases the text size on all sites until you close the browser (Ctrl and - reduces it)
Fixes: 14
Re: Text size
I don't know Mozilla, but in Firefox you can set a minimum font size.
Tools -> Options -> Content
Then in the Font + Colours section select advanced and then set the Minimum Font size that you find acceptable.
Maurice
MikeWhitehead
Re: Text size
Although these methods work the majority of the time, I think if the font is set as a px value the text sizing doesn't work (unless firefox has made a change to allow for it, but it's not likely because of the nature of it).
Only em and % (I think that's the only ones) value font sizes will be altered.
(Anyone to clear this up? Not tried it in a while Tongue)
Fixes: 62
Re: Text size
My site uses a CSS style sheet which defines font size in px and it increases and decreases OK in Firefox and IE7
EDIT - this is not my PlusNet site
MikeWhitehead
Re: Text size
Just checked this and you're right, so apologies for the confusion Smiley
retep
Re: Text size
I did read that you use Mozilla so you may not wish to consider IE7. But IE7's zoom Ctrl +/- (or a bottom right window button) also resizes graphics so does not distort the page as I think other browsers do.
