Text size
- Re: Text size
Text size
04-10-2007 10:41 AM
Re: Text size
04-10-2007 10:46 AM
Re: Text size
04-10-2007 10:51 AM
Re: Text size
04-10-2007 10:56 AM
Tools -> Options -> Content
Then in the Font + Colours section select advanced and then set the Minimum Font size that you find acceptable.
Maurice
Re: Text size
04-10-2007 11:00 AM
Only em and % (I think that's the only ones) value font sizes will be altered.
(Anyone to clear this up? Not tried it in a while :P)
Re: Text size
04-10-2007 11:08 AM
EDIT - this is not my PlusNet site
Re: Text size
04-10-2007 11:17 AM
Re: Text size
10-10-2007 3:39 PM
