Text size on monitor.
Luzern
Seasoned Pro
I find the default a bit too small for my eyes. Using zoom improves it temporarily, but is there a way to alyer the defualt size permanently, that anyone can suggest? I use XP Home SP3 and LG L1710B monitor.
Fixes: 247
Re: Text size on monitor.
Display settings > Appearance > Text size - choose large
HTH
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Luzern
Seasoned Pro
Thanks for aiding the failing grey matter Wink
