Text size on monitor.
- Re: Text size on monitor.
26-07-2009 7:29 PM
I find the default a bit too small for my eyes. Using zoom improves it temporarily, but is there a way to alyer the defualt size permanently, that anyone can suggest? I use XP Home SP3 and LG L1710B monitor.
2 REPLIES 2
26-07-2009 7:31 PM
Display settings > Appearance > Text size - choose large
HTH
HTH
26-07-2009 9:15 PM
Thanks for aiding the failing grey matter
