Testing speed of an ethernet connection
VileReynard
Fixes: 20
Is there any way of testing the local speed of a wired ethernet connection (not internet)?
For example, everything goes via a 100Mbit switch (with a connection to the router for various stuff) and but ideally I'd like to avoid a second PC.
My main PC uses ethernet over power-plugs...
17 REPLIES 17
MartyPop
Re: Testing speed of an ethernet connection
I use LAN Speed Test(Lite) which is available from here: http://www.totusoft.com/index.html
MartyPop,
Never knew about that until now, here are my results:
Version 1.3.1
OS Version: Windows 8
Processor: Intel(R) Core(TM) i7-4765T CPU @ 2.00GHz
Date: 10/23/2014
Time: 14:10:06
Program Parameters: 0
High Performance Timer: 0.0000005132
Test File: \\NAS\Public\NW_SpeedTest.dat
Write Time = 1.1723559 Seconds
Write Speed = 682.3866240 Mbps
Read Time = 0.9891923 Seconds
Read Speed = 808.7406160 Mbps
VileReynard
Fixes: 20
A Linux version would be nice...
HI VileFox
Is this any use :
http://deice.daug.net/netcat_speed.html
VileReynard
Fixes: 20
It looks great.
I shall have to wire up a laptop to try it (nearly everything is wireless).
I tried http://www.totusoft.com/index.html on a Windows partition (wireless)
Version 1.3.1
OS Version: Windows 7
Processor: AMD C-60 APU with Radeon(tm) HD Graphics
Date: 10/23/2014
Time: 15:31:09
High Performance Timer: 0.0000010258
Test File: C:\Windows\temp\NW_SpeedTest.dat
Write Time = 0.2848029 Seconds
Write Speed = 2,808.9602240 Mbps
Read Time = 1.3480628 Seconds
Read Speed = 593.4441680 Mbps
That's for a 100MB file????
It's out by a factor of 100 or more.
Yes, it's for a 100MB file.
VileFox,
Did you manage to make any progress with this?
What is out by a factor of 100 or more?
PeeGee
I must get one of those - 3GBps data transfer, that's 4 to 6 times Gbe speeds Shocked Roll_eyes  Probably not far off 6Gbps SATA buffering speeds though (I can't be bothered to calculate the speed reduction for SATA3 drives in a RAID writing sequential 4k sectors with a 64MB cache Wink - probably "not a lot" as two 64MB caches would hold all 100MB).
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
nanotm
if your using home plugs you should install the utility software they came with and just look at the network speed (every plug will likely be different) there's a lot of network monitoring options around but personally I just open the page in the router that tells me what my lan speed is .....
if I use the router utility program I can even monitor the speed of individual devices, not possible with some routers I appreciate but you don't strike me as the kind of person to use the isp supplied device  Wink
VileReynard
Fixes: 20
Well - I've just got the basic Netgear router, supplied by Plusnet in the early days of fibre.
It has no stats gathering features.  Cheesy
The homeplugs have some Windows software - which is useless to me.
Since the ports are only 100Mbits (about 10MBytes/sec) a proper speed test is a bit hard.
Internet speeds achieve a maximum of 6 MBytes/sec
Anyway, my ethernet card is being difficult at the moment - so I'm buying another one.  Cry
Well for what it's worth my test was based on a 9000 MTU on the NIC and NAS box (via a TL-SG3216 switch) with both ends having full duplex support enabled.
HairyMcbiker
All Star
Fixes: 21
Have you tried iperf?
sudo apt-get install iperf
Then on Computer A:
iperf -s
And on Computer B:
iperf -c <address of Computer A>
On the client machine, you'll see something like this:
iperf -c tim
Client connecting to tim, TCP port 5001
TCP window size: 16.0 KByte (default)
[  3] local 192.168.0.4 port 37248 connected with 192.168.0.5 port 5001
[ ID] Interval       Transfer     Bandwidth
[  3]  0.0-10.0 sec  1.04 GBytes    893 Mbits/sec
I've used it in the past to check the giga nics out.
VileReynard
Fixes: 20
That is a much simpler option.
I tried it on Wireless <--> router <--> Wireless  Cry Cry Cry
The server gave results of
jeremy@debian:~$ iperf -s
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
[  4] local 192.168.1.64 port 5001 connected with 192.168.1.8 port 32855
[  4]  0.0-10.3 sec  6.88 MBytes  5.60 Mbits/sec
Which is why you shouldn't use Wireless...
HairyMcbiker
All Star
Fixes: 21
WoW that is fast! NOT!
