Test of anti virus programs on Android
- Re: Test of anti virus programs on Android
10-02-2013 10:48 PM
http://www.faravirusi.com/2013/02/10/detectia-virusilor-pe-android-test-comparativ-pe-15-produse-de-... and being discussed here http://www.wilderssecurity.com/showthread.php?t=341525
Quote Iata rezultatele detectiei:
IKARUS mobile.security – 562 detectati (92.89%)
Kaspersky Mobile Security* – 519 detectati (85.7%)
F-Secure Mobile Security* - 513 detectati (84.79%)
Avast! Mobile Security – 501 detectati (82.8%)
QuickHeal Mobile Security Free – 493 detectati (81.48%)
G Data Antivirus Free – 485 detectati (80.16%)
LINE Antivirus – 414 detectati (68.42%)
AVG Antivirus FREE – 388 detectati (64.13%)
Zoner Antivirus Free – 387 detectati (63.96%)
Norton Security & Antivirus – 380 detectati (62.8%)
Sophos Security & Antivirus – 369 detectati (60.99%)
TrustGo Antivirus – 368 detectati (60.82%)
NQ Mobile Security & Antivirus (NetQin) – 362 detectati (59.83%)
Dr.Web Anti-Virus Light – 331 detectati (54.71%)
Comodo Antivirus Free – 298 detectati (49.25%)
Trend Micro Mobile Security & Antivirus – 248 detectati (40.99%)
ALYac Android – 244 detectati (40.33%)
BitDefender Mobile Security & Antivirus – 243 detectati (40.16%)
ESET Mobile Security – 240 detectati (39.66%)
IObit Advanced Mobile Care – 191 detectati (31.57%)
1 REPLY 1
11-02-2013 9:58 AM
That is appalling, The best is only <93%
Main problem on android is the apps you install not drive by viruses. When you install it you allow it access and it can do anything track your usage, gps, calls, transactions etc.
