Tesco 32GB data stick
from
http://www.tesco.com/direct/kingston-pen-drive-32gb-usb-20-hi-speed-datatraveler100-g2/469-4973.prd?...
£6.14p each
sorry folks
Sorry, we don't have enough Kingston Pen Drive 32GB USB 2.0 Hi-Speed DataTraveler100 G2 items in stock right now. This item (s) has been added to your save for later basket. You can try to purchase this item again by reducing its quantity.
Fixes: 15
Re: Tesco 32GB data stick
Get the feeling it was a misprice. OOS now when I tried to buy it.
Infinity
It's been OOS  since Thursday 20th @ 5am when first spotted !
MrC
Quote from: Hairy
From my experience (and some of the very negative comments on the 'net generally) Tesco Direct seem to have form for this. It took me 6 weeks to get a printer out of them that they advertised for £49 that eventually they had to buy elsewhere for £169 as they couldn't supply it. I'll not be using them again.
Fixes: 8
http://www.ebuyer.com/239017-kingston-32gb-datatraveler-100-g2-usb-flash-drive-black-dt100g2-32gb suggests it is wrongly priced!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 8
How can you reduce its quantity when you've only tried to order one?
Infinity
That's easy !!!
I found out the hard way...
Buy another one, then when you get to the checkout, just remove one, or all.
Not such a bad price, I bought 2 x 32gb high speed three months back, for £10 each.
Play.com
They work fine in my Freeview HD PVRs.
mushy
Showing in stock and lets you get to the checkout at the moment
Infinity
Always has done, I spoke to CS Thursday, and they promised they would show it as OOS on first web page, hasn't happened yet.
