Terrible broadband speeds on one computer only ..
jerryw
I have bad feelings about getting this problem sorted, but here goes, any help greatly appreciated. Need help! :
- I've had Plusnet fibre broadband for a year or two, and a desktop pc, a laptop and smartphone.
- the desktop is an intel i7 machine with plenty of ram etc and windows 10, up to date.
- so far as I can see the router connection is stable and working OK
- until a month ago I was regularly getting 20-23Mb/s download and 4-5Mb/s upload on both the laptop and desktop.
- but then the speeds on the desktop plummeted. The download speed on the laptop is still around 20Mb/s but the desktop is getting 1Mb/s at most.
So .. I have carried out various basic test and everything claims to be running smoothly. I have bought a new wifi usb adaptor, an Edimax EW-7833UAC and having disabled the previous adaptor, installed it .. no change! Still pathetic ..
I think it must be something inside the desktop OS or wifi software but I don't know where to look. I would roll back the PC but system restore is not offering any old enough dates ..
Can anyone help or suggest what I can do?
12 REPLIES 12
Fixes: 419
Re: Terrible broadband speeds on one computer only ..
Try updating your PC Drivers. I use the free version of Iobytes Driver Booster https://www.iobit.com/en/driver-booster.php It's amazing how many out of date drivers you may find. Note that the free version is slow with updates but gets there in the end.
jerryw
Tried that .. it says it has updated 22 drivers, but no change in wifi speeds I'm afraid
thanks for the suggestion though, interesting software
Oldjim
Resting Legend
Fixes: 63
have you tried a wired connection for the desktop
if that gives full speed it sounds like a wireless card problem
is the wireless adapter internal or a usb plug in device
if internal try disabling and then enabling the device via control panel
if external try unplugging it then plugging it into a different usb slot
jerryw
It is a usb adapter, given time I can connect the pc and router via cable, but it is not easy and I will have to keep that as a last resort. The computer and main BT socket are far apart ..
BUT  .. I have good news and bad news:
- having updated various drivers from the suggestion above, I now find my computer has no sound! Nothing .. if I try to play music the volume mixer says sound is there.. things go up and down .. but it is not reaching the speakers.
- so I thought I would restore to yesterday, but before I do that I will just do a broadband speed test .. heavens, it is back to 20Mb/s! Now, I did check it after updating drivers etc and it was unchanged .. but I have been fiddling with this and that, the computer has restarted once or twice .. and now the wifi link seems to be working properly again!
so I once again have responsive wifi but I have no sound .. I think I am better off but I would like sound too. The audio troubleshooter found no problem.. audio settings look OK ..
Mustrum
Fixes: 77
You could also open task manager and look to see if anything else is using the network on the PC. If you have Onedrive, or any other cloud based drive that could be copying stuff whilst you speed test.
Oldjim
Resting Legend
Fixes: 63
try rolling back the audio driver and are you sure something hasn't changed the default sound device
Fixes: 419
Did you reboot between noticing that there was no improvement in WiFi speeds and then noting the improvement? I assume that Windows only picks up a new driver on initial boot up.
With respect to your missing sound have you checked 'sounds' in your Control Panel settings? I have a Nvidia graphics card which incorporates high definition audio output I also have the standard 5.1 audio output on the PC Motherbird, which is what I use. I have found that this can cause confusion after a driver update and Windows assume that I am going to use the graphics card composite video sound output and set this as the default.
Mav
Fixes: 515
Moderator's note:
Moved to Tech Help as it doesn't appear to be a broadband issue.
Forum Moderator and Customer
ReedRichards
Seasoned Pro
Fixes: 25
The vast majority of 'Driver Updater' programs are cons.  Steer well clear of them.  Get the wrong driver and your computer might stop working altogether.
A computer with a virus might well show poor broadband speeds if the virus is using most of the capacity.  Or one of these borderline legitimate file sharing programs could be using up a lot of your capacity.  Even Windows 10 updates sometimes seem to get out of hand.
ReedRichards
Seasoned Pro
Fixes: 25
I actually saw a problem that might be similar to this yesterday.  Two laptops running Windows 10 could not load many web sites and others did not load correctly, for example http://www.bbc.co.uk/news would show the text but failed to load any pictures.  But I was told that this problem did not manifest on other devices (I did not verify this).  And the connection speed reported by the router was very fast (>22 Mbps ADSL).
The important point is that I was able to fix the problem by resetting the router.  So that might be worth a try if other attempts have failed.  I have no idea why it worked.
jerryw
Just wanted to thank everyone for the helpful suggestions .. at present the broadband speed is intermittently good but mostly still around 2Mb/s and I can't get the sound to work. I don't think it can be a virus or malware because task manager shows no sign of unauthorised activity.
I have decided to give the desktop pc a good going over .. reinstall windows 10 etc
Will report back idc but might be a week or few
Thanks again
jerryw
Just to finish this thread off, in the end Plusnet replaced the router and that has fixed the problem. Nothing else worked..
