Telnet with file output on the client - is this possible?
VileReynard
Champion
Fixes: 16
I can telnet to my router and enter commands.
I would like to be able to redirect output back to my desktop - is this possible?
17 REPLIES 17
MrC
Re: Telnet with file output on the client - is this possible?
Which OS is the telnet client running on?
VileReynard
Champion
Fixes: 16
The client is Ubuntu , so anything (almost) is possible Smiley
I've tried looking at curl - but it doesn't appear to be understandable!
Does;
telnet router | tee -a telnet.log
work?
VileReynard
Champion
Fixes: 16
Thanks chilly!
I never think to use tee Embarrassed
That's going into my "fave-commands" file.
MrC
Quote from: MrC
(Doh, just realised what forum this is  Roll eyes )
Other suggestions from chillypenguin's tee (which is the simplest) are screen or kermit, both of which can capture all output, eg :-
# screen  -L  telnet <router-name or IP>
will give you a file screenlog.0 with the contents of your session. Screen will do a lot more than this - see the man page or Google for the full gory details  Smiley
Mike
Ben_Brown
screen is pretty much my favourite *nix app, use it every day. It's just soooooo useful!
VileReynard
Champion
Fixes: 16
Quote from: Ben
Emacs is too hard for me!  Cheesy
vi  Wink
VileReynard
Champion
Fixes: 16
gedit or nano
Fixes: 21
Since you have changed to editors, try joe (if you grok wordstar commands)
Ben_Brown
It's vi or die I'm afraid Wink
Emacs is just evil.
MrC
Quote from: Ben
As long as we're talking vim and not classic vi - can't live without those split windows Smiley
Quote from: Ben
Emacs is just evil.
No arguing there. It belongs in the same pile of ordure as info.
Mike
VileReynard
Champion
Fixes: 16
Quote from: Ben
Emacs is just evil.
bash: die: command not found
  Cheesy
Ben_Brown
Quote from: MrC
Yeah fair enough. I do really use vim rather than vi. Split windows, key mapping, syntax highlighting and all that good stuff. If you're feeling particularly masochistic, then try vi on solaris Wink It's a bit stricter than most default linux versions I've used.
