Telnet with file output on the client - is this possible?
- Re: Telnet with file output on the client - is thi...
04-03-2009 2:06 PM
I would like to be able to redirect output back to my desktop - is this possible?
Re: Telnet with file output on the client - is this possible?
04-03-2009 3:26 PM
04-03-2009 3:44 PM
I've tried looking at curl - but it doesn't appear to be understandable!
04-03-2009 4:24 PM
telnet router | tee -a telnet.logwork?
04-03-2009 4:45 PM
I never think to use tee
That's going into my "fave-commands" file.
04-03-2009 4:54 PM
Quote from: MrC Which OS is the telnet client running on?
(Doh, just realised what forum this is )
Other suggestions from chillypenguin's tee (which is the simplest) are screen or kermit, both of which can capture all output, eg :-
# screen -L telnet <router-name or IP>
will give you a file screenlog.0 with the contents of your session. Screen will do a lot more than this - see the man page or Google for the full gory details
Mike
06-03-2009 12:01 PM
06-03-2009 12:50 PM
Quote from: Ben screen is pretty much my favourite *nix app, use it every day. It's just soooooo useful!
Emacs is too hard for me!
06-03-2009 10:52 PM
07-03-2009 12:25 AM
07-03-2009 11:01 AM
09-03-2009 9:37 AM
Emacs is just evil.
09-03-2009 11:59 AM
Quote from: Ben It's vi or die I'm afraid
As long as we're talking vim and not classic vi - can't live without those split windows
Quote from: Ben Emacs is just evil.
No arguing there. It belongs in the same pile of ordure as info.
Mike
09-03-2009 12:19 PM
Emacs is just evil.
bash: die: command not found
09-03-2009 1:21 PM
Quote from: MrC
Yeah fair enough. I do really use vim rather than vi. Split windows, key mapping, syntax highlighting and all that good stuff. If you're feeling particularly masochistic, then try vi on solaris It's a bit stricter than most default linux versions I've used.
