Techinicolor TG582n & Vista
danstagg
I have recently upgraded to Plusnet fibre but when I set up the TG582n router I could only get a local connection (no internet). Plusnet sent me out another TG582n but the same problem occurs. The connection seems fine when connected via an ethernet cable. Has anybody else had this problem and can help because Plusnet don't seem to have an answer.
40 REPLIES 40
Oldjim
Resting Legend
Fixes: 63
Re: Techinicolor TG582n & Vista
Moved to Windows board as this isn't really a router problem
Fixes: 158
@Oldjim
At the moment, I do not believe that the OP has provided enough information to determine what the problem is yet.
@Danstagg
Welcome to the forums.
Can you please provide a little more information about the problem?  Your brief description suggests that if you connect your computer to the router by an Ethernet cable, you can connect to the Internet, but if you try to connect via WiFi you cannot connect to the Internet.  Is that correct or have I misunderstood?
If you connect via WIFi can you access the router admin screens on 192.168.1.254?  If not it might suggest the you are not being allocated an IP address over WiFI, in which case can you post the ipconfig output here please?
danstagg
@townman
Sorry for note being clearer but you are correct. Below is the ipconfig when using a wireless connection. I cant get the router page up and when I try to ping the router the request gets timed out.
Windows IP Configuration
  Host Name . . . . . . . . . . . . : Dan-PC
  Primary Dns Suffix  . . . . . . . :
  Node Type . . . . . . . . . . . . : Hybrid
  IP Routing Enabled. . . . . . . . : No
  WINS Proxy Enabled. . . . . . . . : No
  DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Wireless Network Connection:
  Connection-specific DNS Suffix  . : lan
  Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
  Physical Address. . . . . . . . . : 00-24-D2-3A-F8-C8
  DHCP Enabled. . . . . . . . . . . : Yes
  Autoconfiguration Enabled . . . . : Yes
  Link-local IPv6 Address . . . . . : fe80::ad93:d1ea:1ee2:6858%11(Preferred)
  IPv4 Address. . . . . . . . . . . : 192.168.1.65(Preferred)
  Subnet Mask . . . . . . . . . . . : 255.255.255.0
  Lease Obtained. . . . . . . . . . : 18 January 2013 09:13:16
  Lease Expires . . . . . . . . . . : 19 January 2013 09:13:15
  Default Gateway . . . . . . . . . : 192.168.1.254
  DHCP Server . . . . . . . . . . . : 192.168.1.254
  DNS Servers . . . . . . . . . . . : 192.168.1.254
  NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
  Media State . . . . . . . . . . . : Media disconnected
  Description . . . . . . . . . . . : Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller
  Physical Address. . . . . . . . . : 00-13-77-E1-C8-3E
Tunnel adapter Local Area Connection* 6:
  Description . . . . . . . . . . . : isatap.lan
  Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
  DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
  Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
  Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 14:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter Local Area Connection* 15:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Tunnel adapter Local Area Connection* 16:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
Tunnel adapter Local Area Connection* 17:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #7
Tunnel adapter Local Area Connection* 18:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #8
Tunnel adapter Local Area Connection* 19:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #9
Tunnel adapter Local Area Connection* 21:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #11
Tunnel adapter Local Area Connection* 22:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #12
Tunnel adapter Local Area Connection* 24:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #14
Tunnel adapter Local Area Connection* 25:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #15
Tunnel adapter Local Area Connection* 26:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #16
Tunnel adapter Local Area Connection* 27:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #17
Tunnel adapter Local Area Connection* 28:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #18
Tunnel adapter Local Area Connection* 29:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #19
Tunnel adapter Local Area Connection* 30:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #20
Tunnel adapter Local Area Connection* 31:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #21
Tunnel adapter Local Area Connection* 32:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #22
Tunnel adapter Local Area Connection* 33:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #23
Tunnel adapter Local Area Connection* 34:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #24
Tunnel adapter Local Area Connection* 39:
  Description . . . . . . . . . . . : isatap.{F67D4726-27BB-4CDA-86A7-6FC44D6AFADA}
Tunnel adapter Local Area Connection* 40:
Tunnel adapter Local Area Connection* 44:
  Description . . . . . . . . . . . : 6TO4 Adapter
Tunnel adapter Local Area Connection* 45:
  Description . . . . . . . . . . . : isatap.{AE0F5ECE-EB1B-4B0C-8D41-CF92C21FF89E}
Oldjim
Resting Legend
Fixes: 63
Can you install inSSIDer and see what your wireless card gets http://www.metageek.net/products/inssider/
ReedRichards
Seasoned Pro
Fixes: 25
So ping 192.168.1.254 gets a timeout response?  You have probably installed some clever software firewall that is keeping you safe by preventing you from using your wireless connection.
danstagg
@reedrichards
I currently have Kaspersky as my anti virus but other than that I haven't installed anything else
@oldjim
I am currently trying to upload an image of inSSIDer but the insert image button doesn't seem to be working
Oldjim
Resting Legend
Fixes: 63
It takes ages - you have to be patient and if you get sick of waiting click on refresh in your browser - this usually fixes it
Oldjim
Resting Legend
Fixes: 63
If you open Kaspersky (I assume that you have the internet security package not just the anti virus)
Click on settings - top right
Then on firewall
You should get something like this picture - do you have an internet reported  (I don't have wireless)
danstagg
@oldjim
is all im getting when pressing the button
Fixes: 158
@Danstagg
Save the image to your desktop, then use the advanced features below the post text box to attach the image.
Try doing a tracert to Googles DNS servers 8.8.8.8 or 8.8.4.4
@RR
Given Danstagg can get the router admin page up, is it unlikely that a fire wall specific to WiFi is the problem?  If my memory is correct, by default these routers do not respond to pings.
Oldjim
Resting Legend
Fixes: 63
Don't bother with the picture - is your router reported and with a good signal strength
Oldjim
Resting Legend
Fixes: 63
@townman - in post 4 he reports that he can't get the router page up
Fixes: 158
Embarrassed oops read that wrong twice!
Thanks Oldjim!
danstagg
signal strength is showing as excellent and in Kaspersky Plusnet is shown as a trusted network
