Techinicolor TG582n & Vista
- Techinicolor TG582n & Vista
18-01-2013 9:00 AM
Re: Techinicolor TG582n & Vista
18-01-2013 9:03 AM
18-01-2013 9:14 AM
At the moment, I do not believe that the OP has provided enough information to determine what the problem is yet.
@Danstagg
Welcome to the forums.
Can you please provide a little more information about the problem? Your brief description suggests that if you connect your computer to the router by an Ethernet cable, you can connect to the Internet, but if you try to connect via WiFi you cannot connect to the Internet. Is that correct or have I misunderstood?
If you connect via WIFi can you access the router admin screens on 192.168.1.254? If not it might suggest the you are not being allocated an IP address over WiFI, in which case can you post the ipconfig output here please?
18-01-2013 9:26 AM
Sorry for note being clearer but you are correct. Below is the ipconfig when using a wireless connection. I cant get the router page up and when I try to ping the router the request gets timed out.
Windows IP Configuration
Host Name . . . . . . . . . . . . : Dan-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-24-D2-3A-F8-C8
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::ad93:d1ea:1ee2:6858%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.65(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 18 January 2013 09:13:16
Lease Expires . . . . . . . . . . : 19 January 2013 09:13:15
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller
Physical Address. . . . . . . . . : 00-13-77-E1-C8-3E
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.lan
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 14:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter Local Area Connection* 15:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Tunnel adapter Local Area Connection* 16:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
Tunnel adapter Local Area Connection* 17:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #7
Tunnel adapter Local Area Connection* 18:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #8
Tunnel adapter Local Area Connection* 19:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #9
Tunnel adapter Local Area Connection* 21:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #11
Tunnel adapter Local Area Connection* 22:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #12
Tunnel adapter Local Area Connection* 24:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #14
Tunnel adapter Local Area Connection* 25:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #15
Tunnel adapter Local Area Connection* 26:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #16
Tunnel adapter Local Area Connection* 27:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #17
Tunnel adapter Local Area Connection* 28:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #18
Tunnel adapter Local Area Connection* 29:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #19
Tunnel adapter Local Area Connection* 30:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #20
Tunnel adapter Local Area Connection* 31:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #21
Tunnel adapter Local Area Connection* 32:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #22
Tunnel adapter Local Area Connection* 33:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #23
Tunnel adapter Local Area Connection* 34:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #24
Tunnel adapter Local Area Connection* 39:
Description . . . . . . . . . . . : isatap.{F67D4726-27BB-4CDA-86A7-6FC44D6AFADA}
Tunnel adapter Local Area Connection* 40:
Tunnel adapter Local Area Connection* 44:
Description . . . . . . . . . . . : 6TO4 Adapter
Tunnel adapter Local Area Connection* 45:
Description . . . . . . . . . . . : isatap.{AE0F5ECE-EB1B-4B0C-8D41-CF92C21FF89E}
18-01-2013 9:34 AM
18-01-2013 9:40 AM
18-01-2013 9:52 AM
I currently have Kaspersky as my anti virus but other than that I haven't installed anything else
@oldjim
I am currently trying to upload an image of inSSIDer but the insert image button doesn't seem to be working
18-01-2013 9:54 AM
18-01-2013 9:59 AM
Click on settings - top right
Then on firewall
You should get something like this picture - do you have an internet reported (I don't have wireless)
18-01-2013 9:59 AM
is all im getting when pressing the button
18-01-2013 10:00 AM
Save the image to your desktop, then use the advanced features below the post text box to attach the image.
Try doing a tracert to Googles DNS servers 8.8.8.8 or 8.8.4.4
@RR
Given Danstagg can get the router admin page up, is it unlikely that a fire wall specific to WiFi is the problem? If my memory is correct, by default these routers do not respond to pings.
18-01-2013 10:02 AM
18-01-2013 10:03 AM
18-01-2013 10:05 AM
Thanks Oldjim!
18-01-2013 10:08 AM
