Tech help needed please
ak1200
Hello fellow plusnet users sorry if this not in rite place on forum but am trying to find out something & hope you could help,
If i go to copy files from my pc using the media server app Tversity over to my ps3 using a hardwired connection (lan) will the amount of data tranferred be added to my monthly usage cap.
I colud just unplug my external hd which hooked upto ps3 an tranfer files directly but this would save me having to move lol  Smiley
Fixes: 62
Re: Tech help needed please
If all you are doing is moving files from the PC to the PS3 then it won't go anywhere near the Plusnet servers so no usage recorded. You could however check by disconnecting your router from the internet and see if it works.
Fixes: 189
I can confirm what Jim has said as I copy a lot of stuff between my PS3 and media server - doesn't count at all.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
