Task Manager Status
- Re: Task Manager Status
Task Manager Status
02-03-2008 10:30 AM
Having nothing else to do, this Sunday morning. (I`m going to start a spreadsheet on Monday),
I had a look at my Task Manager, as I had clicked on Windows Explorer 3 times and nothing happened....
Here is the table from my Task Manager......
I was surprised to note that there are 5 instances of explorer.exe and 7 instances of svchost.exe
Can anyone tell me if anything is amiss with this (51 processes running)
Dell Inspiron 2200 Laptop 80 gb HDD 256mb ram Windows XP SP2
Task user cpu mem usage
(Note….. ALL tasks are .exe except soffice which is .bin
Explorer g 0 3256k
quickDCF g 0 668
Explorer g 0 3268
Svchost SYSTEM 0 244
Explorer g 0 9456
Explorer g 0 3272
Net Meter g 0 1656
Fumoei g 0 300
Eraser g 0 568
Jusched g 0 88
Zlclient g 0 2808
PDVDServ g 0 272
Avgas g 0 976
Igfxpers g 0 244
Hkcmd g 0 268
WLTRAY g 0 2084
Hpztsbo4 g 0 404
Avgcc g 0 288
Taskmgr g 0 4404
Soffice.bin g 0 1472
Wdfmgr LOCAL SERVICE 0 76
Explorer g 0 12860
Svchost SYSTEM 0 1108
RichVideo SYSTEM 0 112
HPZipm12 SYSTEM 0 200
BOCore SYSTEM 0 200
Avgemc SYSTEM 0 1368
Alg LOCAL SERVICE 0 156
Vsmon SYSTEM 0 11504
Svchost LOCAL SERVICE 0 2472
Svchost NETWORK SERVICE 0 956
Avgupsvc SYSTEM 0 832
Soffice g 0 80
Svchost SYSTEM 0 14048
Svchost NETWORK SERVICE 0 1156
Svchost SYSTEM 0 1084
Lsass SYSTEM 0 1252
Services SYSTEM 0 1380
Winlogon SYSTEM 0 812
CSR's SYSTEM 0 1552
Smss SYSTEM 0 84
Avgamsvr SYSTEM 0 460
Guard SYSTEM 0 348
Aawservice SYSTEM 0 356
Spoolsv SYSTEM 0 584
BCMWLTRY SYSTEM 0 2004
WLTRYSVC SYSTEM 0 76
System SYSTEM 0 64
System Idle Process SYSTEM 98 28
Sorry about the out of line columns.............. copied and pasted from MS Pub
Anything I can delete..... disable/stop running?
or any other advice please.
Explorer g 0 3256k
quickDCF g 0 668
Explorer g 0 3268
Explorer g 0 9456
Explorer g 0 3272
Net Meter g 0 1656
Fumoei g 0 300
Eraser g 0 568
Jusched g 0 88
Zlclient g 0 2808
PDVDServ g 0 272
Avgas g 0 976
Igfxpers g 0 244
Hkcmd g 0 268
WLTRAY g 0 2084
Hpztsbo4 g 0 404
Avgcc g 0 288
Taskmgr g 0 4404
Explorer g 0 12860
BOCore SYSTEM 0 200
Soffice g 0 80
Lsass SYSTEM 0 1252
CSR's SYSTEM 0 1552
Smss SYSTEM 0 84
Guard SYSTEM 0 348
System SYSTEM 0 64
3 REPLIES 3
02-03-2008 10:38 AM
The 7 svchosts are normal as they are core windows communication applications - the same app has multiple functions.
The 5 explorers are not. You should only have 1 explorer running. You can safely kill off the explorer processes and when you kill the main one your screen should refresh and explorer starts again automatically.
02-03-2008 10:42 AM
Thanks for that Peter............. have noticed that when I click on Outlook Express recently, it shows the blue OE box, then disappears with the windows Plink Plonk.. (!) I then have to click OE again to get it to stay on the screen , so this is probably the reason for that....
Is there anything else there that you think I could do without, to improve start up time? although I`m not too worried if there isn`t
03-03-2008 8:40 AM
Under normal circumstances you should only have one explorer.exe.
HOWEVER
If you have the system setting "Show each explorer window as a seperate process" then you will have one explorer.exe for each window that you have open, +1 (for the start menu/desktop)
B.
HOWEVER
B.
