TalkTalk Speedtouch 585v7
- TalkTalk Speedtouch 585v7
18-04-2010 6:54 PM
I got a thomson TG585V7 from ebay, thinking i could use it with plusnet. Now, i need the PLUSNET router firmware for it to work (according to someone) Is there any way i could get that Firmware? (Ive got the Thomson update software) and, luckuly i have my Netgear DG834G to use until i get that firmware
Regards and Many Thanks
Aman
Aman
3 REPLIES 3
Re: TalkTalk Speedtouch 585v7
18-04-2010 7:00 PM
You shouldnt need the PlusNet specific f/w, the standard Thomson f/w will work ( unless your router is locked to TalkTalk ! ).
All the f/w's are available here http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
You may find though, that if it is locked, you may not be able to upgrade the f/w.
19-04-2010 10:34 PM
It appears that it may be possible to unlock them, with a bit of brute force and ignorance. The possibility of bricking it looks high though!
http://forums.whirlpool.net.au/forum-replies-archive.cfm/1189178.html
Regards,
Neil
Regards,
Neil
21-04-2010 11:26 AM
Hello,
All done! Router on PlusNet now. Thanks to all of you who helped.
Aman
Aman
