Tablet stuck in start up
- Tablet stuck in start up
01-11-2014 7:02 PM
There is no reset button. I have tried holding combinations of buttons on start up. I opened it up but can't see a button cell, such as you would have in a pc. So no idea how to erase flak memory and force it to reset. Not even sure if it is possible to do so.
The tablet was cheap nearly a year ago, so physical experiments are an option. Just doing this to see if it's possible and learn how they physically work.
Re: Tablet stuck in start up
01-11-2014 7:49 PM
Anything here useful?
Forum Moderator and Customer
01-11-2014 10:19 PM
03-11-2014 11:30 PM
Anyone for a game of Frisbee?
Come on TorpC, this is your field of expertise. (You on a sabbatical?)
04-11-2014 10:38 AM
If it is new then return it.
If you can't return it then you need to get the ORIGINAL FIRMWARE for it. Then flash it again, you will loose everything on it.
Things to try before the above.
leave it for about a week, then try and if it doesn't even power then plug it in and try again, this may have cured it - had it work in a couple of tablets.
Look round the edge for a small hole (not the mic) insert a pin and see if it clicks this maybe the reset button, power up and press it.
Failing all the above do you know the model of tablet what processor etc?
04-11-2014 10:48 AM
Tried various power button combinations, to no avail. Going to download something called srs which allows access to android systems through pc/laptop. See how I get on.
I have already separated it to see there is an internal power cell, like the button cell in most pc's, but can't see one. May try disconnecting battery too drain any residual power, to see if that resets it.
Going to try the physical stuff first, as I really want to see how they work, and software issues are pretty much universal and cross platform.
04-11-2014 10:53 AM
Goto Techknow if you know your tablet name then they maybe able to help you.
To get access to android from a pc, you really need the usb debugging enabled on the tablet, and since you can't boot it you can't enable it. Unless it was on by default (unlikely)
06-11-2014 1:41 PM
before doing that though ensure and usb or sd cards have been removed,
if that comes up with a list scroll down to the factory restore option (if the touch screen doesn't work use the volume buttons to scroll and the power button to select)
it should spend a few minutes reinstalling everything from the rom and then work as before
