Tablet Kept On Charge
- Tablet Kept On Charge
28-01-2014 4:59 PM
Re: Tablet Kept On Charge
28-01-2014 5:42 PM
( just pulling the mains plug on my laptop..... thanks for the reminder ! ! ! )...
28-01-2014 5:47 PM
To condition it, just charge use and discharge to empty several times.
We found this on laptop batteries. I conditioned my several of my colleagues didn't. Result when they WANTED to use it on battery it lasted about 30 min. (Mine was 2+ hours on IBM laptops)
28-01-2014 5:52 PM
Quote from: valart My laptop is always connected to the mains I hardly ever use the battery
As HB recommended on conditioning laptop batteries (he beat me to it)
As the Tablet batteries are not typically designed to be changed / swapped out etc I would only recommend charging them when the notification pops up typically with 15% battery life left
28-01-2014 11:05 PM
Quote from: TORPC typically with 15% battery life left
As much as that?! I drain mine down to below 5% and only then do I plug it in. I'm very religious about it and I can still easily get over 3 hours out of the original battery from 2009!
28-01-2014 11:31 PM
29-01-2014 12:38 AM
29-01-2014 7:23 AM
29-01-2014 1:00 PM
However, regardless of high or low usage, good housekeeping or environmental abuse, Li-ion batteries have a shelf life. Due to the internal chemistry, after four years they are on their way out - even if they have been hardly used and recharged less than 500 times.. And after six years, batteries that last month were giving three hours, may last no more than three minutes. Be wary of replacement batteries that have been in the shop for the past 18 months as their internal chemical clock is already ticking. Factory fresh is very important here!
Incidentally, dead Li-Ion batteries can be recycled at PC World/Currys - some supermarkets only recycle alkaline and zinc batteries.
+++ edit +++ When recycling any high capacity battery (camera phone laptop), even if it seems 100% dead, always tape over the power terminals as there is a very remote chance that an electrical short inside that bin of dead batteries may cause unintentional heating. This precaution ensures it was not your battery that burnt down the recylcing plant.
You can store batteries unused and disconnected for months on end at 40% charge. Some people even store batteries in the fridge to extend shelf life - but this does expose them to damaging condensation and possibly, drunken idiots at 3am!
30-01-2014 8:35 PM
Quote from: shutter Laptop batteries..... and I suspect, Tablet batteries.... are designed to be charged and discharged , so keeping a laptop "on the mains", is, doing the battery harm.... I do the same thing, but about once a month, I just pull out the mains supply, and let the laptop drain the battery... I would suspect the tablet battery would need much more often "non charge use"... to keep the battery in its optimum condition.... ( until it actually dies... if you follow... )..
Unfortunately not correct. Lithium ion batteries will suffer recharge damage which is proportional to the logarithm of the degree of discharge. A one tenth discharge and recharge will do orders of magnitude less damage than a full discharge and recharge,which is why a full discharge should be avoided. Leaving them on charge all the time will do no damage at all. Google recommends that the batteries for its Nexus range are recharged at no more than 50% discharge to prolong life.
31-01-2014 9:16 AM
Why have them... ? just fit ordinary alkaline batteries and do away with the charging circuitry... make tablets and laptops cheaper.
31-01-2014 12:03 PM
31-01-2014 12:25 PM
31-01-2014 12:28 PM
31-01-2014 12:49 PM
Given the composition of the various Lithium batteries and the intelligent charging used, the batteries are usually maintained within operating parameters.
However, the biggest problem with Lithium batteries are letting them discharge beyond the point where recharging is advisable through idleness (of the device).
Batteries gradually self-discharge even if not connected and delivering current. Li+ rechargeable batteries have a self-discharge rate typically stated by manufacturers to be 1.5-2% per month.
And don't forget, if using Lithium batteries in other devices (especially without discharge protection) failure to follow current and voltage limitations can result in an explosion!
