TV defaults to Hub Manager screen
stevemul
When I turn on my LG smart TV from standby, I get the Hub Manager screen and have to choose " Guide" on the remote to get it to be able to find a program. Can anyone tell me how to switch off this default? ThanksIMG_4813.jpeg
Tags (2)
3 REPLIES 3
Fixes: 251
Re: TV defaults to Hub Manager screen
Done check the TV’s networking setup. Ensure that the get network address is set to automatic / DHCP.
How is the router connected to the TV? WiFi or Ethernet cable? If the latter, to avoid doubt, on a Hub2 the only use of the 4th LAN port (coloured differently) is to connect to FFTP ONT connection. It should not be used for connecting devices.
Fixes: 585
@stevemul  you probably need to change the power-on screen of your TV. It seems it might be set to 'Home hub'
See here https://www.lg.com/us/support/help-library/lg-tv-how-to-set-specific-input-startup--20153529242384
Mav
Fixes: 518
Moderator's note(s):
Thread moved from Broadband to Tech Help.
Forum Moderator and Customer
