TV as monitor?
- TV as monitor?
- « Previous
- 1
- 2
- Next »
Re: TV as monitor?
09-12-2014 10:43 PM
Re: TV as monitor?
09-12-2014 10:47 PM
You need a separate Audio lead to use the TV speakers and "probably" to dive into the Setup menus to make sure the correct Audio input is used for that external video input.
On my TV only one of the 2 HDMI inputs is configurable that way.
Re: TV as monitor?
09-12-2014 10:49 PM
Quote from: 7up Should have thought of that really with your supreme intelligence
Thanks, but I wasn't really trying.
So you have a TV set without a VGA input and a computer without an HDMI output. Your favourite colour is red and your mothers' name was June. Or maybe I don't read minds and it's best to mention the technical details for my benefit - or in fact for the benefit of anyone else trying to help. You haven't said what graphics output ports you have on the computer nor if your TV has anything other than an HDMI input.
Re: TV as monitor?
09-12-2014 11:27 PM
as to the output /input system there's a plethora of options in terms of adaptors or leads available in the under £5 bracket, although if I'm honest I would just list the tv with no sound output on ebay and use the cash from that to buy something more fitting for the space.
split screen on a single display is horrible to work with unless you spent a lot of money and use the proper display input box, what you suggesting would best be achieved by having the tv and a monitor with the same resolution and you would require dual outputs from the gfx adaptor, failing that get a cheap low profile gfx card off ebay (again theres often plenty of them for under £20) and you don't need a soldering iron to make them work
Re: TV as monitor?
10-12-2014 10:35 AM
Re: TV as monitor?
10-12-2014 2:36 PM
Quote from: HPsauce I regularly use DVI to HDMI, but remember that will be video only.
TV has scart and i *think* it has HDMI but can't actually find the instructions to confirm this. I was never really worried about sound but as i say the first few replies seemed to indicate that image quality may be a problem so i don't think i'll bother now.
Re: TV as monitor?
10-12-2014 3:24 PM
My issue was when attempting to use the mouse and keyboard for general use. As the TV is wall mounted it was uncomfortable to be looking up while bending over the laptop.
I have also connected the PC to the plasma with similar excellent displays but same issue regarding using keyboard and mouse.
Forum Moderator and Customer
Re: TV as monitor?
10-12-2014 3:46 PM
Re: TV as monitor?
10-12-2014 5:13 PM
I did have the manual around here somewhere but can't find it..
Re: TV as monitor?
05-01-2015 12:42 AM
Well with a little bit of cash that came in recently i've managed to acquire a DVI -> HDMI lead
I've dragged out one of my old computers (single core 2.8GHz Celeron D) with a dual monitor output (one VGA and one DVI) for testing on our main TV. It's great for youtube but as a second monitor (at 60Hz) it does start to make the eyes feel a little sore after a while!
Note to ReedRichards: When I said i had no DVI / HDMI output i meant on my desktop computer before you start . Completely forgot about the old redundant one which does have DVI.
Anyhow, youtube works ok (alright.. single core, flash being cpu heavy, it gets a bit glitchy here and there but its the best i can do) and it seems ok for general purpose video watching from files on the HDD so I'll leave it at that.
As for the spare TV upstairs.. with low refresh rates making my eyes sore i won't even bother with it! Infact i may have a mate who wants it if i can fix the sound..
Anyhow thanks for all your advice chums..
Re: TV as monitor?
05-01-2015 1:19 AM
And yes, that is a real american Western Electric 500 telephone...
Re: TV as monitor?
05-01-2015 1:31 AM
- « Previous
- 1
- 2
- Next »
