TV aerial splitter ?
- Re: TV aerial splitter ?
07-12-2011 10:31 PM
so i recently bought a white surface monted box with two outlets thus giving me 2 connections inside but what i have found that not so long the conections break down and loose signal again :-[.
inside the box there is a resistor that has a solderd joint between the sockets has broken now twice.
so what i need is a conection from my aerial to the bedroom upstairs then down outside to the living room , hopefullly to last more than a few weeks .
any help appreciated
07-12-2011 10:37 PM
Or you can use something like this in the loft and run two separate feeds http://www.maplin.co.uk/2-way-f-splitter-29530
07-12-2011 10:41 PM
07-12-2011 10:53 PM
07-12-2011 10:56 PM
The +1 one is the high powered output I feed to the splitter which feeds the TV and the DVD Hard Drive recorder via a set top box
08-12-2011 7:54 AM
08-12-2011 8:30 AM
Now that we've had DSO in this area, I can get away with passively splitting the connection without the amplifier. As others have recommended - get a proper all-metal one, preferably with F-connector sockets (and don't forget to buy some F-connectors!)
You may even find that replacing the building contractor-grade coax with some decent satellite-grade (CT100 equivalent) will allow you to split without an amplifier.
08-12-2011 8:32 AM
A good source for advice and parts is: http://www.satcure.co.uk
08-12-2011 8:41 AM
08-12-2011 12:47 PM
08-12-2011 1:05 PM
