TV Card Viewer
- Re: TV Card Viewer
TV Card Viewer
17-09-2015 2:10 PM
I have a TV card installed in my PC and I used to use Windows Media Centre to watch and record live TV.
Having moved to Windows 10 where WMC no longer exists, I'm looking for a simple free app to use,replacing what WMC did.
I have tried Kodi (XBMC), MediaPortal and NextPVR but they are either complex to set up for live TV or simply don't work.
Does anyone please have a replacement for WMC to work in Windows 10?
5 REPLIES 5
Re: TV Card Viewer
17-09-2015 2:17 PM
Google is your friend..
result......... http://www.howtogeek.com/132462/5-alternatives-to-windows-media-center-on-windows-8/ ;
watch live tv on windows 10
Re: TV Card Viewer
17-09-2015 2:25 PM
Depending on the make of the card, it probably came with software that you can use in place of WMC.
If not, this one appears to be free.
Re: TV Card Viewer
17-09-2015 2:51 PM
@shutter thanks, I did try some in that list before making this Topic.
@avatastic Thanks, I'll have a look at that one which I haven't seen before.
Unfortunately I have misplaced the disc that came with the card.
I can download the application but it needs activating with the original CD
Re: TV Card Viewer
17-09-2015 5:36 PM
Quote from: Strat I can download the application but it needs activating with the original CD
Hauppauge?
Have you looked at MediaPortal 2? It no longer has a dependency for MySQL, which makes configuration a lot simpler if you aren't used to setting that up.
Re: TV Card Viewer
18-09-2015 5:44 PM
Quote from: Strat
I'm under the impression that MediaPortal works with Win10 so I assume you must be discounting it because you've formed the opinion that it's too complex to set up.
I've been using MP (various version 1) for about 2 years and IMHO it's not really too complex to configure, and the benefits are well worth it. For example MP enables you to watch/record all the channels on a single multiplex per tuner, whereas I believe WMC can only handle a single channel per tuner. e.g. BBC1 HD, BBC2, HD ITV HD, CH4 HD and BBC3 HD are all on the same multiplex so with MP you can watch/record all of those simultaneously with a single DVB-T2 tuner against WMCs choice of a single channel from that list.
One tip which I've followed is to install a RAMDisk for the Timeshift Buffer (which is used when watching live TV) to save having the files being constantly written to a physical HD which obviously saves a good deal of wear. Another tip worth following is to install the LAV filters when offered.
If it's of interest I've got 2 x TBS Quad tuners installed (TBS 6285 and TBS 6985, although the satellite one is not being fed at present) and MP handles many simultaneous recordings trouble free.
