TP Link w8990 and FTP
pn78
Had this router up and running from day 0 - with no problems.
It has two usb ports that I can connect a usb disk to - and then access by ftp.
Whilst I can access this over my home network  I can't get this to work for away from home and I'm not sure where the problem lies , router , ip address (for www NOT intranet).
Any ideas people
2 REPLIES 2
Fixes: 356
Re: TP Link w8990 and FTP
You will need to configure the w8990 to allow ftp access from WAN ( for a guide google 'tp link ftp server application guide w8990' ).
Also bear in mind that you IP address can change unless you have a static IP.
You also need to check your PN firewall settings http://www.plus.net/support/security/firewalls/firewallfaq.shtml
VileReynard
Fixes: 20
But don't use ftp - it isn't secure. Try ssh or sftp.
