TP-Link-TD-W8960N Help needed with wireless drops
St3
All Star
I have one of these http://www.amazon.co.uk/TP-Link-TD-W8960N-300MBPS-Wireless-connections/dp/B0031SUB4S/ref=sr_1_2?ie=U...
The internet works fine, but ive noticed the wireless connection drops 3-4 times a day, i accessed the router after a 24 hour reboot and found 68 errors for wireless and 0 for internet.
Im really not clued up with routers and got this one new 4 months ago recomended by a friend.
I think an issue could be that i dont fully understand all the router setup, i basicly installed it and ran basic setup and added plusnet details.
As i say the net works fine no issues, its just the laptop connection drops 2-3 times a day and at the same time we loose connection to our mobile phones.
normally after 4 mins it connects back again, or i have to reboot router and it works again.
The router has the latest firmware as ive checked all that. I just wonder if my config is setup correctly?
http://tinypic.com/view.php?pic=dpzcrs&s=6 this shows the current config of my wireless atm.
Hope someone can help Wink
Win 10
i7 7700k
GTX 970
Fixes: 4
Re: TP-Link-TD-W8960N Help needed with wireless drops
A coupe of reports of it dropping signal in the comments on that Amazon page.  Might be a problem with the device itself.
dccrepairs
You could try changing the wireless channel but I think I would have to agree with Kelly
Fixes: 4
Quote from: Kelly
A couple of reports of it dropping signal in the comments on that Amazon page.  Might be a problem with the device itself.
St3
All Star
So its more likely to be a fault, i just want to make sure its somthing to do with the way it setup, before i see about returning it.
Win 10
i7 7700k
GTX 970
Fixes: 21
You could try in the Wireless Advanced section, changing the Mode to 11bg or 11n only which ever works best with your missus phone. See if that helps.
Fixes: 4
hmm.  I didn't mean to empty quote there, but I can't remember what I meant to say.
