TP-Link 300Mbps Wi-Fi Range Extender & Booster
Vaswani
Afternoon All,
I just have a very simple question regarding TP-Link 300Mbps Wi-Fi Range Extender & Booster.
Currently I have I have a 2704n router and the coverage is not very good in some parts of home.
Please can someone confirm if TP-Link 300Mbps Wi-Fi Range Extender & Booster is compatible with my 2704n router?
OR if is there is another brand or product you recommend then please let me know as well.
Many thanks for your time.
Kind regards,
Munish
1 REPLY 1
Fixes: 418
Re: TP-Link 300Mbps Wi-Fi Range Extender & Booster
@Vaswani  welcome to the orum.
Yes it is compatible. However as you say the 2704 has terrible WiFi performance..
I would spend about the same amount of money on an auction site such as Ebay and get a BT Smarthub 6. You might find that you do not need an Extender. Setting instructions are pinned at the top of the router board.
